- Thread starter
- #21
@a31gun: I'd assume that will only work if your battery is in good enough condition to actually hold some of that charge, otherwise it's just wasted time and energy. You can take your battery to pretty much any auto parts store for testing. BTW, I believe the general consensus was to go with the Diehard vs the Optima - same battery, less price. I have a Duralast Gold in mine.
I have not yet made myself the jumper device to fix this issue. Actually, it has not happened again since the one day when I ended up pulling and bending/tweaking the fuse prongs to wedge in there tighter. Since I have most of the parts already, I will end up making a pigtail adapter like in the threads above, to use the stock EFI relay with an aftermarket fuse holder in place of the questionable 20a one.
- BTW, I had wife inquire with service rep about this problem when she took it in for service recently -- they said they can't do anything about it unless it's physically showing the problem right then as there's no way to chase down that type of gremlin unless it's showing it's face....also they don't really "repair" stuff like this, they replace whole effected circuit/component (like the whole fuse box in this case). This would likely mean towing it into the shop and a fuse box replacement....yeah, I'm good with a $3 DIY attempt before going that route.
Good luck to anyone else who experiences this issue.
