so are the 2018 and 2019's affected also? What about 2020 and 2021? I know my 2015 is on the list, but no fix yet.
Can you give us a better description of what you felt at what miles per hour and if it happens every time or did it Happen on and off? During what conditions would you see vibration happen? I want to see if I can duplicate it with my 2015 LX570.Mine was replaced under the recall last week - 2.5 hour job. A mild vibration under throttle c 50mph seems to have disappeared subsequently
After a couple of weeks it seems the fuel pump replacement actually made little difference. It is a very slight shudder that appears on and off, always at low revs (sub 2000) and circa 50-60mph. Never at high revs even when in this speed range. Have had it checked by a master tech at the Toyota service centre 3 times and he insists it is ‘normal’.Can you give us a better description of what you felt at what miles per hour and if it happens every time or did it Happen on and off? During what conditions would you see vibration happen? I want to see if I can duplicate it with my 2015 LX570.
Sounds like a torque converter vibration. Have you changed the fluid in the transmission? How many miles?
But your not located in the USA?Done. Was not notified by Toyota. Checked my VIN manually and it was on the list, went to the dealer and they said oh yes we will change it. Did that but didn't feel any difference.
Was contacted by Lexus Dealer today, appointment on Friday to get it done.
I just checked back with the Dealer.... yes, fuel tank is removed for the recall.
EDIT: More info:
EDIT: More info:
