I've had two Land Cruisers, a '74 FJ40 and my current rig, an '85 FJ60. I had good times in them both and eventually they both got the 350 treatment. On the 60 I built a couple of variations of the 2F with mixed results. I finally came to the conclusion that my friend, a machinst/parts store owner was right; there is only so much much that can be done to a 2F. On the other hand, the 350 I put in my 60 (a gen II block with roller lifters, Vortec heads and a carefully tuned Quadrajet) with the help of a Mark's bellhousing adapter along with an H55F that I already had, made more power than I thought it would and used less fuel than I thought it would, less than the 2F did. There are things that require welding, like brackets for motor mounts. You have to get a power steering hose made to go from the Saginaw pump to your Toyota box. I ran a self-exciting regulator in the Chevy alternator because there was no source for 5v in a Cruiser which is what that particular alternator required. All in all it went fairly smoothly and I have only one regret; that I didn't do it sooner.
