Rear upper links - height sensor (1 Viewer)
Missouri
Needing to replace my rear links but I need to keep the height sensors intact - I'm lifted with the extended Airbagman air bags. None of my searching has found upper links other than the OEM that have a bracket to mount the ride height sensor.
Has anyone replaced their rear links while keeping the ride height? Who makes the links that accommodate this? If not should I just go with the OEM - they obviously lasted 16 years.
I think OEM probably has the best bushings, aftermarket can be stronger but it’s usually the lower links that get bent from hits.
Apache Offroad sells a kit with rear upper, rear lower, and panhard.
They also sell the upper rear links separately.
Moog replacement LCAs definitely have the sensor bracket. I used them 3 years ago in my rig when I refreshed the suspension. They were exact copies of the OEM links (at least externally) and were like $40 each on Rock Auto. They've been fine for me so far in my lifted application, although I did go ahead and delete the rear bags.
