@bloc &
@linuxgod,
Gents quick update since both of you provide some useful info….
I got the 2722 and BP-51 installed in rear and truck looks great!
I’m bummed I didn’t take measurements pre install but going from 11 yr old stock springs to 2722 the lift in rear was WAY more than what was listed on ARB website (0.75”). I believe in the range of 2”+. I love the stance and amount of rake (pretty much level loaded).
The drive is noticeably better. I haven’t played around with compression and rebound settings beyond initial setting to slightly firmer than recommended from OME.
I think only downside is now I want bigger tires
I’ve been reading on forum and looks like 295/70r18 is largest tire I can fit into apart carrier under truck. Are either of you running oversized tires and did you have to do much if any trimming given 200 with 2”+ of lift? FYI I’m currently running tundra takeoffs with 60mm of offset.
Also have either of you used any sliders to protect spare from damage?
TIA
