Rear Spring Spacer Question
San Diego
Website
youtube.com
Soooo
Now that rig is basically set weight wise, and dialed in with spring rates, I’m looking to raise the rear 3/4-1”
I got front Bilsteins at 3rd clip and rear OME2721 with the Bilstein shocks
Spring rates and ride is dialed and im happy, but with the fridge and tools and such, rig is sitting almost perfectly level.
Looking to add a little rake, aka raise the rear, but keep the 2721 rear springs
What say the Mud People?
Searching made my head hurt and added more confusion
Thanks
Soooo
Thanks
OME makes some trim packers that IIRC can be stacked p/n OME80PR10.
There's also this option.
Thanks
I guess I’m asking more of which one are preferred?
Do the poly ones creek and make a racket after they get wet or dirt in between then and the coils?
Had a lot of poly bits on my tundra and most of them made a racket, drove me bonkers
But…. I think those Amazon ones in the 1.2” flavor might be perfect, as it sagged about 3/4” after all the weight was added
Thanks
Ah, that I am not aware of. I have no personal experience with either, just know this is what a number of folks here run on their rigs. Perhaps they can chime in. Would like to know myself as I will likely add them to my rig sometime this year.
I think that @TeCKis300 fella has some if I’m not mistaken. Maybe him and others might chime in
I just did this exact same thing. Was happy with my rear spring rates, but have started keeping a little more weight on board so wanted a little butt lift.
Ever since I deleted AHC I've run a 15mm superpro coil spacer on the driver side and it's been silent. ~35k miles now.
I recently actually just got the 30mm amazon ones linked above to do my butt lift. I installed the 30mm on the driver and moved the 15mm to the passenger since I only needed a little boost. It's been about 500 miles so far and so far so good. I'm pretty sure @TeCKis300 recommended them at some point in a post I seen.
Perfect! Exactly what I was wondering. Thanks
