Long time listener, first time caller.
I recently picked up a 1984 fj60 as a winter beater. It came with 33's (10.5) and seems to sit normal to maybe an inch high in the rear. I notice on full flex, the rear tires rub the inner wheel well. Also, it has the old fj40 wheels, and using search and FAQ, i think they dimensionally the same as the originals.
I do notice the fronts seem to sit about right at the fender line, but the rears sit inward about an inch to an inch and a half.
Is it OK to just run spacers in the rear only? Has anyone done that? How deep of a spacer?
I did see the rear track is .6" narrower than the front track in stock form, so I don't see why the rear being wider by 2 inches would pose much of an issue, and I think it would look much cleaner and solve the rubbing.
I'm not experiencing any problems up front with rubbing on brakes, tre's, or the wheel well, that i read about while searching, so I'm reticent to mess with it and cause one issue while fixing another.
I did spend time on search and FAQ and while I learned much about wheels and spacers, I could not find any experience or opinions on my specific question.
Thanks for any guidance.
EZ
EZ
