Rear Locker swap question
Asia
Hello everyone. I have 2003 ujz100 v8 landcruiser with atrac and center diff lock. Can i install toyota factory rear locker from diesel land 100 from different region? if so what parts should be swapped or replaced? some 2003+ land100 have rear lockers so wondering if they can be easily installed in my car ?
As long as the gear ratios match front to back, it's completely possible.
At a minimum, you'd need the rear third member and actuator assembly, the short side axle (longer splines on a locked application), and it wouldn't hurt to find the wiring sub-harness and the computer.
I followed this thread: Adding F/R lockers to 2003 Land Cruiser. Even as I'm sure your choice in parts is better than ours, most of the discussion there should walk you through what's needed.
