Rear hidden subwoofer box
Merritt, BC
I made a custom sub box to fit behind the rear panel where the OEM sub was located. It's a very tight fit, but after testing it for a few weeks now, I'm extremely impressed with how it sounds for being such a small box. I'm no woodworker, this is probably the most I've done since high school shop class, but I still found it fairly simple to build.
This Dropbox link contains the sketchup file and pictures with dimensions.
The subwoofer used is the Pioneer TS-SW2502S4. This sub only requires .35 cubic feet, and this box comes in at just a hair over that.
I've never built a sub box before, so these two websites were incredibly valuable:
How to Build a Subwoofer Box | KICKER®
Speaker Enclosure Volume Calculator
5/8" MDF was used, and I wouldn't recommend any thicker as there isn't a whole lot of space to work with. The only thing I would probably change if I did it again, is to sink the subwoofer into the box a little bit, but there isn't much room left in the box to push it in further so you'd need to use a router and shave off some space inside the box to allow this.
I used one small brace between the front and back pieces, just to minimize the chance of any vibrations.
Because it sticks out beyond the box, I had to use some foam to keep the panel from contacting the cone when it hits really hard. Other than that, the panel fits back on almost perfect (slight bulge where the sub is, and I didn't snap in the bottom two snaps on the panel). Foam was also used around the edges where the box contacts the body of the truck, to minimize vibrations and rattles.
If you dont have sketchup or use dropbox, the last image has the dimensions listed.
It would be really awesome, if at all possible, to have the speaker mounted completely inside the box. The membrane travels a lot at higher volume and it will likely touch the plastic quarter panel cover producing an unwanted rattle.
Really nice work and design. I was a lot more lazier and bought the Pioneer box matched to the speaker itself.
I actually said in the post that I'd recommend that ;) I used some foam to keep the panel away from the woofer, no rattles yet. There's not a lot of room to work with, so you'd need to router out some of the back panel to sink it in a bit.
do you think 1/2" mdf would be strong enough since it's not a very deep box?
also, is it secured anywhere to the sheetmetal, or just wedged in there? My old sub just dies last week and contemplating new solutions. Thanks again.
Probably, I would just add some extra bracing. 1/2" would probably give you enough room to sink in the subwoofer as well. I guess it depends how hard you like your sub to pound, I listen at a medium volume so it would probably be fine. If you listen to your music really loud it may vibrate.
Nope, it's an extremely tight fit and can't move, I just have that one bracket you can see to keep it from sliding up
Don't forget that water can drip down from the molding below the rear sliding windows. Toyota just uses foam donuts to seal the holes.
Hmm, I'll have to look around in there. I don't have the sliding windows, but I did notice a drop of water on top of the box the last time I had the panel off, might have to look where it came from.
I did seal the box though. After it was all assembled, I coated the box in two coats of 50/50 carpenters glue and water, then after it dried, sanded and painted with rustoleum outdoor paint, so it shouldn't absorb anything.
It's not from the sliding window, but from the molding below it:
image-2907125516-jpg.742607
Picture stolen from this thread:
Wet Rear Seat Belts???
You might be fine with the prep you did. Personally, I thought I'd use some plastic to make an angled 'roof' over the box I'm planning.
Ah, I see. Yeah, I'll have to look into making something to divert the water, or maybe just throw some silicone around the holes and seal it up.
