Would removing the console rear heater hoses and all push more heat to the primary heater? I'm guessing not but if it does I'll pull the hoses.
My rear heat won't blow hot. But front gets the rig so toasty warm I gotta turn it way down. These things heat great.
The front heater should burn you up.With both on in below freezing I cant stand them both on. Mike
The heater core is probably all corroded up inside- so hot coolant can’t flow through it. No fix.1988 FJ62.
My rear heater still blows air but recently stopped blowing hot air. Any suggestions on how to troubleshoot?
Depending on the cause of the clog. If it's legit corrosion then you called it. No fix.The heater core is probably all corroded up inside- so hot coolant can’t flow through it. No fix.
