- Thread starter
- #21
Thanks for the comments everyone. Johnny- unfortunately I don't have any shots of the seats before I put them in. The difficulty was that they do not mount to a flat surface easily. 3dogs- yes rounding the corners would be a good thing. I was planning on that as well as capping them just simply ran out of time. I'll get it next time its out though and post some pics up. How would you tie in to the body? At first I thought of running a longer bar that the front could also tie into. I'd have to remove the stock tie in in the front to do so. I looked at what was anchoring the bolts for seats and seat belts in my other cars to get an idea of how the industry is required to do it- often if was not much more than a smallish section of thicker plate welded to the sheet metal of the floor. For race harnesses they often just say put some big washers in under the mount. In this case however the frame has to hold the entire weight of the seat and passengers so maybe I should beef it up a bit. Usually that would be accomplished by 3 mounting points per side and in this case there are only 2.
And the reason you should not do it the way I did is that you should find something that would be easier to get into the truck. This took too much time to fab up due to the fact that the seat belts were not integrated and the bases for the seats were not for a flat surface (and because I'm damn slow!) The outboard supports were 2" or more lower than the inboard. I live in japan and I can not read- so I just have to go with what I can get easily and make it work. If I could have easily found a set of fold and tumble seats with headrests and integrated belts from another 4x4 then that would have been the way to go.
I may be taking it out again and throwing it into a bj43 while I tear into some rust issues on this body. Other thoughts on improvements are surely welcome.
Thanks-
Pete
Thanks-
Pete
