Rear Evap Core Removal
I see the 4 Seasons Parts Rear Eval and Expansion Valve. I have a couple of questions....
The electrical device on the side of the rear expansion valve, is that a solenoid shut off or control flow regulating device? How the fit of the 4seasons Parts?
I have 381K miles and my LC developed engine oil leak, Front O ring around the oil pump and rear O ring behind rear main oil seal retainer plate. I pulled the engine to repair these leaks, decided to replace Alternator, Starter, AC compressor, all the heater hoses, by pass hoses and radiator hoses along with a new radiator while the engine was removed. I changed the front trans converter input seal, cam - crank seals, oil pump, tensioners, t belt and drive belt. I did replace the Condenser removable filter / moister absorbent bag. I evacuated and recharged the system and really hot day the front system would get warm and then get cold, pressures would both rise and both fall together and compressor would not cycle. The rear unit with front unit low blower, would stay steady pressures. 1/4 pound more freon and the system stabilized and stopped having pressures rise and fall when front blower is on hi. I was feeling it was a bad expansion valve in the front at first.
My manual says removal of Dash is required to remove front Evap / Expansion Valve Unit. I purchased a front Evap. Expansion Valve, Rear Eval core, rear Expansion Valve 4 Seasons. I on the fence to send the parts back, or if they are correct parts keep them for when I have to break the system open. So far, it's steady cold when 104 degrees outside, cold front and rear. When I removed the glove box, I see a dash part that crosses the evaporator it's not removable unless I cut it out and adapt it to be bolted back in blocking the removal of the EVAP core. I was able to remove the cover of the evap core to clean the evap core and case.
Has anyone modified this crossing dash part that the glove box attaches too to allow removal of the Evap core without having to remove the dash!
Exactly, that was the piece that was not working on the unit from my first attempt. The one I bought originally did not come with the electrical device so I removed the old one and added it. I guess I damaged it in the process because when I went back in the electric device was not engaging. (you can check it with a 9 volt battery)
Oh yeah that's right you have to cut the dash part! There's a thread on here that does into detail, I did cut. I also bought this part from fellow Ih8mud user
I mean if it's cycling cold and warm it's because the pressure is not regulating in the system. There's only three moving parts ( Compressor, and the two expansion valves) in the systems so it's pretty easy to diagnose and even easier to just replace all the parts.
The expansion valve for the rear I linked above came with the electrical device and it was just plug and play.
Oh thank you...for the reply....
It appeared the rear by logic was a flow control solenoid Off / On. when I shut my rear unit off and unload the evap heating Blower Low my pressures would stabilize and ambient temp 98 it would only pull down IDLE now, to 42-45 PSI low. Fan in front of radiator, 1500-2000 RPM pull down to 35 ish and cool good. Now load the evap with heat, Hi blower same outside conditions pressures would rise and fall together, rise about 50 psi and loose cooling, drop under 40 cool again. H block Expansion valves control Super Heat an AC temp, liquid level of refrigerant in EVAP. It sure was acting like a bad expansion valve in front. I added 1/4 pound and pressures normalized... stayed steady no when Loading the Evap with heat, Front or Rear unit on doesn't matter. Front fan comes on just over 250 PSI and cools pretty good now. That little freon level change and expansion valve like it. I preordered all the parts in and saw the glove box thing. I been driving it in Texas heat daily now 95-105 degrees and no trouble so far. Not like my Lexus IS car Electric fans, and freeze you out on 100 degree day idling. but not bad ...
