Hello folks,
I have question about the pressure valve or a one way valve for the rear drum brake on my 79 Fj40.
Just bought the truck last month and notice there is no brake fluid flow to the rear drum brake , no brake fluid flow out of the one way valve (pressure valve).
Take the valve off and clean bunch of junk out of the valve, remove the spring, the piston and the seal like a little cup for good cleaning and still not working.
My question is when I removed the piston, the seal cup is pointing downward.
Anyone know if the seal cup should be pointing upward? so the fluid can flow through the valve and should block the flow from coming back?
This valve has an arrow for directional flow just like a check valve.
I installed the piston without the seal cup than I have brake fluid flow through the valve. Tested drive around the block,now I have too much fluid flow to the rear drum brake and cause the rear drum to lock when the brake paddle is apply.
Any help will be greatly appreciated.
Thank,
Charly
Thank,
Charly
