rear differential is banging when I take off!
Taos, New Mexico
Is anyone familiar with this? I am certain I will need to pull the 3rd member to find out what this is. Any comments before I go elbow deep?:crybaby:
The only thing I'd suggest before getting elbow deep is to stop driving it until you find the problem. :frown:
Are you sure it is in the diff and not the rear shaft needing to be greased?
I havent pulled it apart yet as I have never heard this before today. low Greased axle will do this???..... it sounds like it is slipping for a split second and....bang! it engages.
The drive shaft has new ujoints as well as plenty of grease in the yoke and joints.
I guess I should state that it only bangs once and then it runs fine. when I stop it does it all over again. One bang and off we go!
check
Check for play in the driveshaft at the rear as it leads to the third member.
Do you have an auto locker like an Aussie or Lockright?
Pinion nut, flange bolts, inner splines on axles or axle, improperly toleranced locker install. retainer clip failure. Ring or pinion gear tooth damage.
Somebody smarter widdle this list down a bit??
Howdy! Sounds like you need to drop the rear DS and test the pinion bearing preload by rotating the flange back and forth. You may have to put a lot of torque on it to see if it is creeping in and out of the nosecone of the diff. That's a bad sign if it is. John
did this new noise coincide with the new ujoints?
Did everything get marked so when the new ujoints were installed the shaft went back together correctly?
just a thought...
Tim
Last time I heard something like what your describing it was replacement gears that fixed it.
When starting it bangs like its not aligned but the bang aligns it. Around a turn it bangs like the shift miss aligned it and it had to "bang" to realign.
If thats what it sounds like, I'd say its time for new gears in the 3rd member.
