Trail Taylor provides an excellent repair option.
Not an easy project, and I had the body off the frame.
I am jealous of how clean your frame is!I did the same as mentioned above where I sliced the heads off with the air chisel then punched thru with the air hammer punch. On the rivets that were thru more than 2 pieces of metal I had to use heat as well. They wouldn't budge no matter how hard I went in on them. View attachment 4026371View attachment 4026372
The key is not giving up. LolI am jealous of how clean your frame is!
That being said, the air chisel I’ve got is not even coming close to cutting off rivet heads but I’m using an Astro tool one… I suppose I could go buy a bigger one, but I’m gonna try the drill and torch method next.
Picked up and oxy acetylene cutting torch yesterday. Now I’m just waiting for the rain to quit having a tropical storm/typhoon floating around out there is not helping.
Daniel
Okinawa, huh?I am jealous of how clean your frame is!
Daniel
Hey Jason, thank you very much!A quality air hammer is a must. HF smoothie tools aren't going to get it done without a lot of extra elbow grease and consumables.
I have two air hammers with attachments I use for this job.
AIRCAT 5250
SNAP-ON PH3050B
Both are higher end chisels and if you hit the pawn shops you can usually find them for 1/2 price. Both make quick work of the rivets.
Jason
Kevin,Okinawa, huh?I used an angle grinder with a 40-grit flap disk and that made short order of removing the rivet heads. It's the drilling that is the hardest part of this operation.
