concretejungle said:Hey, nothing wrong with a little kentucky crome right!![]()
The hanger seems to be doing the job quite well for now. Remember, i'm jobless at the moment, so cash is tight.
So what's the deal with that CE code? What's the fix?
The downstream O2 sensor looks at the exhaust gasses. It wants to see the same pattern as the upstream sensor, only to a much smaller level, meaning the cats are cleaning up the air. What your's is seeing is way too much oxygen from the leak. It doesn't match up with the upstream O2 so it throws the code. The fix is to either get your exhaust fixed, which may be a bad gasket at that flange, or it might actually be a cracked flange that an exhaust shop welder can fix in about 30 seconds. Or you can buy a downstream O2 emulator that tricks the ECM into thinking everything is cool all the time. People use them when they eliminate the cat to make the OBDII system think they are there. In your case, that would be a silly option.
