Real time help-rear axle work (1 Viewer)
Frankfort, KY
When I put the rear shafts back in do I HAVE to have new paper gaskets, or can I use blue RTV like I'm sealing the diff with?
I usually put permatex over the old gasket.
My old paper jobbies got destroyed when I pulled the shafts. Is permatex just like silicone?
RTV will be fine if properly prepped, etc. It's neither a heated nor a pressurized joint, so rather benign in the scheme of things.
DougM
43422-60040 x2......$1.12 a piece.
Problem is, I need it NOW so I can wheel on Sunday. I'm gonna rebuild both axles after the wheeling season, so I'm gonna go OEM end to end at that time.
If you do make your own, a used empty cartridge (rifle or pistol) makes a good punch to make round holes for bolts. The edges are pretty sharp - otherwise it can be tough to make round holes.
Charlie
