Slomo
It's Complicated
I need a quick measurement from someone with a totally stock 80. I need to know how many turns from centered to right lock and how may turns from centered to left lock the steering wheel turns in degrees or like a clock, whichever you are more comfortable with, that a factory 80 is. I need a stock 80 with stock tires that has not had the steering stops on the axle adjusted to keep larger tires from rubbing. This is not possible on mine anymore as the factory stops are no longer there. I can estimate but Mr T spent a lot of money to determine the safe operating angle of the birfields at full lock and I would just as soon not exceed that even if the tires still have room to clear.
Of the thousand or so measurements I took before I started hacking stuff off that is one I forgot.
Cheers
Cheers
