Real Time - brake line fitting size (1 Viewer)
Wichita, KS
I swapped out my flex lines and found one of the hard lines too short. Do any of you guys know what size the fittings are? I want to call the parts store before I trek my a*& down there and get that dumb high school dropout deer in the headlights look. Thanks much.
the 62 took 4.75MM sometimes called 3/16" metric, concave double flare, be aware as there is also a buble 4.75mm out that with convex fittings,
the 80 should be the same,
but as long as your hard lines are not damaged I woudl leave them alone, much easier to get a longer soft line than to bend up, flare and install hard line,
took me better part of a day to track down parts for and make a hard line for the front of my 62, was a real PITA and the quality is not as good as OEM.
RT
Thanks for the return. The flare was buggered up (I've never seen a flare saver/conical that small) and the hard line was too short. The line was the short one on the right side just above the flex line. I got lucky I had a hard line stashed in my tool box from another vehicle that fit with no drama. Thanks again.
