Real time brake help (2 Viewers)
Use a brass drift or a piece of wood to punch the bolts out so you don't ruin the bolts. Don't be afraid to use some force.
Is this the stage you're at?
replacing front rotors and need to seperate rotor from hub. i reference the manual, and didnt get anything... any assistance?
you need to press out the wheel studs. I guess you can also hammer them out, but you might mess up the threads, if you want to reuse them.
after that, there are 2 14mm bolts that hold the rotors to the housing.
does that make sense?
cheers,
j
