Everytime I have pulled a rear 60 diff or replaced a rear semi float 60 shaft I have had to tap it into place with a lead shot filled mallet to get it to seat fully in the splines and slide into the outer bearing and seal.
How weird. I've install axles for other trucks and I've never seen anything like this before.How dumb is this? A smear of gear oil on the seal and that baby slid right in..... View attachment 2415739
I was convinced there was a clearance issue with the axles and maybe there was. I painted the bevel and found some knicks in the paint where I assumed it was hitting. Maybe that happened somewhere inside the axle housing and wasn’t hitting the carrier?Still not cooperating? Man, what is going on?
As for the shaft clearancing, we have run across this just a few isolated scenarios. ARB even put out a bulletin on the Toyota shafts as they are notorious for having some odd clearance/machining at the diff side. I suspect it’s a combination of a slightly lower bevel carrier and a slightly ”excessive” material shaft.
As for why they won’t go in now? I can only assume a bent housing but as @Steamer mentioned, some require a fair but of muscle to get them to drive in. Remind me did you change anything at the outside end such as bearings or seals?
Wow! I was really confident it would've been out. Guess you don't owe me that beer now lol. Still a scratcher.I did that actually. And it was perfectly in round. Yeah, I know. Head scratcher...
What a PITA?! I’ve not had to do a head gasket... yet... can’t imagine doing all that work and having it blow out immediately.when I was a shop technician I would have these situations that cost me a lot of anxiety and stress. Irritates the hell out of me why can't Automotive manufacturers make parts that are not too difficult to remove. It's rare that I've ever had a head gasket failure when I did a new head gasket on a vehicle. One day I did a head gasket change on a Chevrolet V6 engine. I think it was the 3.4 but it's been so long I can't recall. I promised myself that once the heads were on and the cooling system was sealed I would never install any other parts and do a pressure test on the cooling system. Well this Chevrolet failed the coolant pressure test and was leaking between the head gasket and the head on the inside. I was so angry that I ripped off the intake and remove the heads within 2 hours. I was completely exhausted. I think It Happened One More Time and I believe we did have the heads Foursquare and flatness. I'm glad you got over your situation and it was not your primary vehicle!
