scottm
I need to pick up paint tonight. I went a little thin on the first coat about three years ago, but it's held up perfectly. There are a few spots where the concrete is beginning to crumble, and the epoxy went with it. The previous epoxy came with a clear-coat, which I applied over the epoxy, but I doubt much clear is left. The clear-coat wasn't a two-part, not sure what it was, but obviously it was compatible with epoxy. I didn't use sand in the mix, and it's never been especially slick when wet. I'm not sure if it was the slight texture in the cement, or the clear coat, that seems to give some wet traction.
The first time, I cleaned and rinsed like crazy. I used muratic acid and detergent. I plan on the same this time, and assume the acid won't hurt the epoxy. I don't know what paint I'll buy, I suspect they're not that much different, the key is the prep.
Any repaint experience?
Any thoughts on stabilizing the crumbly spots? Hopefully going thick there will do the trick.
