I need some advice from the experts.Ive had a clunking and a dead spot in my steering since I picked up my pile. The problem seems to be that when the ram assist cyl extends the whole steering link rotates on the tie rods and "bottoms them out". The way it was set up, the ram is not parallel with the link. We're thinking this can easily be solved by rotating the link so the 2 ram mounts line up keeping the ram parallel. This is what we plan to try anyhow. In the pic below you can just make out the ram between the links and can see the shaft end mount on the tie rod. The ram is higher at the axle mount and lower at the link mount.
What I was hoping to get some advice on is the swivel balls at both ends of the ram. The barrel end swivel at the axle mount has some play in it and my buddy has offered to machine it and press in a hardened shim. This would eliminate the little bit of play but Im wondering if getting rid of the swivel ball would have any negative effects. There would still be a swivel at the ram end but if the ram is parallel to the link would the swivels still be needed?
Its all apart now so Im going to mess with it on the weekend and see what I can come up with.D
