Radius Fabrication "LS1" filter airbox interchange (2 Viewers)
Pinckney, MI
Hey folks,
I have a Radius airbox on the way for my LS swapped 80. I didn't realize until after I payed, that the filter it uses is not available in the US. It's a Holden Commodore filter that isn't used in any US domestic vehicles.
Has anyone found a locally available filter that would interchange with it? I'd hate to be stuck with a situation that I need to source replacements from Australia.
Thanks
-Rob
I need to know this as well, so I did a bit of research.
These are the alternatives, according to Aiftiler-crossrefence.com
Putting the GM (OEM) filter into Wix and it comes up with a Wix 46913. It is designed for a Holden Adventra 2004-2005 and a Pontiac GTO of the same era. Holden Adventra is an off-road version of the Holden Commodore.
There is a 6913 Napa Gold Air Filter as well.
Filtering filters on Amazon for a 2005 Pontiac GTO comes up with a few filters that look to be the right size.
I might order a few to check and have on hand.
Yeah, the US got Holdens rebadged as a Pontiac GTO/G8, Chevy Caprice, and later Chevy SS. Decently active community with them too; finding filter shouldn't be hard unless it's using some oddball AUSDM-only spec.
Looking to get the Radius air box. Where did you source it from?
I bought it direct from Radius. It took months to arrive and shipping was a fortune. Great parts though!
-Rob
Directly from them. Shipping was reasonable at first but then they came back for more.... There are one or maybe two US distributors.
I did pick up these air filters from Amazon, pictured on the right, and they look to be a good fit.
Not one picture dang guys
I ended up mounting my airbox “incorrectly” using some different holes in the fender. It’s tilted towards the fender, raising the outlet to clear my lower radiator hose. Seems to work well with only two bolts, though I’ll make a bracket to support the “floating” side later.
-Rob
