I need some help with wiring.
I have several wires in the back of the radio. Antenna is obvious. Two grey wires go to the speaker in the glove box.
Then I have three wires which look appropriate for the radio. Unfortunately, though, it seems they are always on.
I tested the red wire which is connected to red/blue and it is always on even without key in ignition.
I tested the yellow wire and it is also always on also without key in ignition.
The black seems to be a ground.
I thought one of these would turn on only with the key turned to accessory. If this is not the case and I need to get a new wire to be key on only, does anybody have a picture of the fuse box location for this?
