As I continue to work through this cruiser, I replaced all of the big radiator lines, the thermostat and fan clutch over the weekend when I discovered this:
The passenger side radiator support has popped loose. It's been driven like this for a while now. Not sure if it's something that can be repaired/welded or not. It's not leaking and it appears to have been replaced by a PO so I'm not even sure what model it is as a can't find any tags or part numbers on it. I believe it's a brass core one but can't confirm.
Here is the completely intact side for reference.
On a side note. I'm assuming they destroyed the fan shroud when the radiator was replaced as it was broken when I unbolted it to replace the fan clutch. How would one go about ordering parts from CDAN as I've never done it before.
Thanks for any help on this
