Radiator cap issues(0.9 to 1.1) (2 Viewers)
How would you know if the radiator cap is not working? Can it lead to overheating especially on idle with aircondition on. Is 0.9 radiator cap ok.
Your radiator, fan and water pump need to keep the coolant temp below the pressure rating of the cap. If the temp/pressure exceed what the cap can handle it will allow the over-pressure to escape into the catch tank before your radiator blows out. If you are losing coolant without overheating, the cap is probably bad.
If you have an older truck with no overflow bottle, there should at least be a small outlet tube under the radiator cap that is connected to a tube that directs the overflow to the ground. If your truck is like mine when I got it, there was no hose/tube. The fluid just puked all over the top of the radiator. Look for crusty residue the color of your coolant around that outlet or all over the radiator fins. Or add a bottle so you can keep an eye on it.
Somebody more well-versed than me can confirm this, but around 1975(?), Toyota switched over to an overflow bottle and a different cap that was designed to let the coolant overflow at high temps, then draw it back into the radiator as it cooled off. It's my understanding that if you want to add a functional overflow bottle that allows this two-way flow of fluid, you need to replace the cap with the later cap designed for this function.
Yes i.have a overflow bottle im just not sure if my cap is correct 0.9 and not sure if its working properly
If you have a spring scale (like a bathroom scale), place the radiator cap on it, and push down with your hand until the spring compresses. It should compress around 13 lbs (0.9 bar) force. Inspect all the rubber seals (2 of them) for rot. If all else fails, buy a new cap.
If your overflow bottle overflows (beyond the design limits) this can indicate a bad cap as well.
