he said that included front seals, water pump, timing belt etc.
Front seal meaning CV boots?
I am looking to buy a 2000ish 100, and it seems a lot have not had this done. I'm trying to budget and bargain accordingly if I have to have it done.
Just curious, which shop gave you the quote?
Hey Petro,
I have used Pratt automotive, they are great, I just got a qoute for my GX470 which needs the same items for $980 parts and labor.
Timing belt
Serpentine belt
H2O pump / with gasket
Thermostat / with gasket
Drain block / flush radiator
Idler pulleys
Crank Seal
Cam seal x2
Here is thier info:
Pratt Automotive
817-249-0800
Then you can come in and do the fluid / filter changes for the rest of the 90K service, well except a trans flush which is $159 at Freeman Toyota. Hope this helps
Erik
Discount OEM parts will run you $400ish (use beno or CruiserDan from this board) with waterpump and all the goods. Then it's all labor, which varies from $500 for independent shops to over $1k for dealerships.
