I'm having some problems with my dash lights after replacing some bulbs and putting in a new head unit. That whole "CHARGE FUSE" circuit as a "ground path" is proof that engineers hate us and want us to be miserable.
At any rate, I won't dig into that here. Right now I have one very simple, quick question that I want to verify:
Shouldn't the L Wire terminal on the alternator itself be grounded when the car isn't running?
That is to say, if I put one connection on negative and another on the L terminal on my alternator while my car is off, it should be a 0 ohm connection, right? I have found some hints that this should be the case but nothing explicitly stated anywhere.
Mine has infinite resistance so I think my regulator is bad. But I just want to verify this simple check before replacing the alternator.
Thanks,
~Josh
Thanks,
~Josh
