I'm getting parts and info organized to do a desmog on my 60 soon. One option for my smog pump is a second alternator. I already have an extra 55am alt, so that's paid for. I already have a dual battery system, so the obvious way to do this would be similar to how godwin and kevin did theirs...one alt per battery.
https://forum.ih8mud.com/60-series-wagons/94294-fj60-dual-alternator.html
https://forum.ih8mud.com/60-series-wagons/222516-130-150-extra-amps-2f.html
I am currently using a VSR (voltage sensing relay) to charge the second battery. System works fine for 4+ years.
My question is about combining batteries when using dual alternators...Can you combine the batteries with dual alternators (eg for winching)? What I'm not clear on is whether two alternators "fight" each other when they're linked up?
I already anticipate using a switch to choose which battery to run the truck from...so I can isolate one as the starting battery while using the other for in-camp use.
If I can combine them, then my plan is to delete the VSR and instead use one of these marine switches to switch between or combine the batteries when/if I want.
Any advice is much appreciated!
Thankyou!
Thankyou!
