Questions for the Spool Gun Gurus.
splitshot
Head cook, Bottle washer, and Peace keeper.
Rodent Central, Az
New to me spool gun set up my neighbor can't use due to an older Lincoln with no CV option...(he picked them both up as a used package).
Connections are straight forward, any specific settings I need on my 'ol MM Vintage before I fire this up?
And
I have 2 wire speed controls, one on the module and a remote on the gun itself (gun overrides the module setting)?
Any steering would be appreciated.
Online research has produced nothing so far, doubt I will get anything from Miller or Lincoln's tech support because of mixing a competitor's product with their own. Worth a try though.
Any favorite welding forums?
I'd do a specific search on the net about that control module - they sort of have their own setup and settings versus what the spool gun demands from what I know...
Sarge
Spot on, follow up, they are not compatible. If you are looking for a aluminum spool for your Miller in the future might want to bookmark this;
Spool Gun Hookup Chart - MillerWelds
They all do the same thing, so you should be able to make it work with a CV power source as long as it can run wire all by itself. It won't be as flexible and easy to set up as an integrated unit. You just need to get the voltage and wire speed dialed in.
