Hey folks, busting my ba//s today
on the BJ70, changing out every fluid, belts, valve adjustment etc. I have lots left to do tommorrow, and I have some questions.
Napa and Toyota both pull out a spin on filter when I ask for a fuel filter, all well and good, but it sure as hell doesn't look like it's going to fit my truck
Mine also has wires coming from the bottom, so presumably the cover stays, and the filter must be immersed inside? Anyone have a NAPA part #?
Here is a mystery device between the grill and the rad...is it my water separator?
There is a grease nipple inside one of the u-joints that is impossible to get to...is there a trick or do I have to buy a special tool? I am able to get to all the rest of them.
If a u-joint is bad enouh to cause the vibration I get when decelerating and using engine braking, shouldn't it have visible play in it? All mine seem tight and solid.
Finally, here a shot of the engine, 1/2 way done cleaning her up...hard to get the soot off the paint...kerosene seems to work.
