I rebuilt my transfer case last spring and never was able to measure the pre-load on the output shaft bearing as accurately as I would have liked.
Now, I'm having a shop do a transmission swap on my truck and asked them to measure the transfer case preload. Was measured at 12 inch pounds, which is what I remember getting when I rebuilt the case- this measurement is lower than the required 13-21.4 inch pounds for new bearings.
The transfer case bearings have about 3k miles on them since the rebuild. Should the current shim be replaced to get a reading more in the middle range of the specs? Also, since I've put those miles (3k) on the transfer case since rebuilding it, should I go by the new bearing preload specs or used-- which is something lower like 6-10 inch pounds?
Thanks.
Thanks.
