I was wondering about another possible way to cut and turn for SOA. Let's say you want to go SOA, could you first go ahead and weld your top spring perch parallel (or slightly angled for ideal caster) to the existing bottom perch and now go ahead and mount up your axle. Now the pinion angle will be pointing in the wrong direction but your steering geometry should be preserved since all you are doing is placing the spring on top of the axle. Now could you just take a heavy pipe cutter and cut the axle tubes somewhere in the middle (or wherever is convenient) and now rotate the differential upwards as needed and reweld the axle tubes. You could reinforce the rewelded area by plating with a piece of pipe cut lengthwise and welded over the joint.
If this has already been done or if this is an unoriginal concept please let me know but it seems like it would be easier and faster than first setting the pinion and then cut and turning at the knuckles. In my mind it would be easier to accurately set the pinion angle by cutting and turning at the axle tubes, you could scribe a mark along the axis of the tube and cut perpendicular to the mark. To ensure the tubes remained straight you could set them in the vee of a heavy piece of four or three inch angle iron and clamp them down before you reweld.
Let me know if this makes sense or if you know of why this wouldn't work but to me it seems that it would be faster and easier than the traditional way.
