Grench
I'm trying to picture this in my mind. Are you saying that you can remove a birf without getting the cone washers out?
When you remove a birfield, you're removing that side's shaft as well, right? If not, what prevents the axle from slipping outboard/inboard and pounding on the spinning diff?
I know there are several write ups about birfield repack/rebuild in a garage/shop setting. If I were to put everything needed to field replace a birfield in a toolbox, what would that toolbox contain?
Those who have done this field repair; do you haul around a gallon of gear oil and a keg of birf grease? Or do you leave whatever is packed in the housing in place and put the packed birfield in and let them mix counting on pulling it apart again in the shop?
I'm running Longfields and chromolly shafts. Should I still carry a spare birfield? Axles? At some point the spare parts & tools & fluids list/weight starts becoming substantial. Does it become overkill at some point?
Thanks!
Thanks!
