Pulling engine with no crack in manifold-To header or not
I have a '99 LC with 415k miles that runs fantastic but needs some maintenance. PO was a mechanic but did what was only needed when the part failed. When I asked him when the last time the timing belt was done, he responded with "timing belt?".
Guess that is a real testament to these rigs and engines. I have 2 other 2UZ rigs, '04 S/C Tundra with 125k miles and '04 S/C LC with 74k miles and this engine is quieter than either of them.
So I have a bunch of work to get this '99 correct and a bunch of parts piled up. My question is the current exhaust manifolds don't have a leak, and I love how quiet they are. I know the job to replace them while the engine is in the rig is a pain, but what are my chances of doing this job and not cracking the current manifolds? Doug Thorley headers aren't cheap, but should I just bite the bullet and plan on these manifolds not surviving the work I'm about to do?
Appreciate any input.
The exhaust manifolds aren’t anywhere near the timing belt so the chances of them surviving are very high. If you’re doing work that requires the engine to be pulled I would seriously consider installing headers even if your manifolds aren’t yet cracked.
Pulling the engine to do a bunch of work. Timing belt, water pump, fan bracket, starter, alternator, power steering pump, steering rack, front diff, etc.
