Why is this guy bringing this garbage into the thread? Nothing helpful. Is this the MUD spirit? Where’s the ban hammer??
Me too man, if not I’ll be in the looney bin, I’m pretty mechanical and have owned nothing hit yotaI hope you figure it out. I have a ‘13 as well, had it going on 10 years now. I’m at ~95k miles with 80-90% of those off roading or pulling my ~7k lb camper 100% on crappy Alaska roads. It rids like butter on my winter P metric Hakkas, more brick like on my summer LT Ats. I’ve had no issues with the AHC and plan on keeping it a long time, probably will be my last non-EV (have 2 Teslas and a reservation on a Cybertruck, Rivian, and Silverado EV)
Yea I kinda agree, I mean it keeps the thread at the top but contributes nothing to it? Oh well, we’ll figure this out MUD don’t you worryWhy is this guy bringing this garbage into the thread? Nothing helpful. Is this the MUD spirit? Where’s the ban hammer??
I agree… just wasted my time and nothing helpful or productive.Why is this guy bringing this garbage into the thread? Nothing helpful. Is this the MUD spirit? Where’s the ban hammer??
Regarding your 33" p rated tires... How is the acceleration and does your truck get into 6th gear and stay there?I replaced mine…damping is hard to put into words.
Going over a speed hump, I note that the suspension sort of catches the truck and allows it to bounce down and up in a controlled manner…go too fast and even with new globes, it will exceed the cushy damping capability of ahc…the difference in the vehicles ability to catch itself and slowly arrest movement up and down over speed humps was the most stark change. Albeit still somewhat subtle.
Dropping down a curb, same thing.
The difference in damping was comparable to going from around 40 psi in a tire down to 28.
Going down the highway you notice nothing because damping is not occurring much and your old accumulators probably had enough capacity for this. Hit a big enough pot hole at speed and you notice nothing because the dip exceeded the damping capability of the system…go slow enough and even with almost no damping capability in your own globes you notice nothing…but in between speeds of super slow and fast on flats, you’ll notice an improvement that is marked.
If you’re running lt tires at the recommended psi, especially in the 32-33” range, even with brand new globes it’s still going to be a moderately harsh ride.
I went from 40 psi light truck tires (recommended psi) down to 27 psi 33” passsnger rated coopers and the ride improvement is dramatic. Rarely does the damping capability of the rig even come to mind now. The ride is “back to oem” as far as I am concerned…partially also, I believe, because the weight of my tire and wheel package is back within oem specs.
Wheel/tire weight as well as psi matter as it relates to how much energy is going up into your suspension system…and then back down through each bump.
If you want the ultimate ride: 21 lb rock warriors (with no rock ring) and 43 lb cooper 285 70 r17’s at 26 recommended psi…I don’t think it’ll get better than that. 64 lbs on each corner (vs 78-84 oem for an lx570) will be significant imo.
Also, it tools weeks after my globe install before the vehicle would readily drop into low neutral and high…probably because I erred in the bleeding process and it took a while for all the bubbles to make their way out.
If you’ve done accumulators and you have your psi in your tires appropriate and you’re not rolling on 90+ lbs on each corner, and you still haven’t seen a marked improvement then my guess would be you’ve got a bit of air in the ahc system that may make its way out (or you could try bleeding it)
Nice! But what about the 4-runner?Update to this issue, I cleared some space in my garage to get the truck in there, only level ground I could find, did the height calibration, adjusted all the shocks to be in spec, then did the YAW sensor reset, got an alignment and the truck drives amazing now. Feel like the suspension is dampening as it should. Handles well, tracks true. Something must have been out of whack bad before but I appreciate all the ideas in the thread and input from the community. Pain in the ass for sure but made a huge difference in the ride.
Not sure, we’ll go look at it, if/when it comes in, not sure they are getting any more 2022’s, we can get our deposit back if we opt out of it. My wife does like the quality of the LX over the 4Runner and the size isn’t too much bigger, but she still thinks it’s a large truck to be driving. The good news is the truck drives great, I’ve been fixing the small things as I go, just ordered new rear lift struts for the hatch. It’s rust free, will be having it sprayed with New Hampshire oil coating in a month, so if she chooses the 4Runner so be it, I hopefully won’t lose a ton on the LX, it’s a rust free relatively low (66k) mile truck that’s here in the north east, and will be protected from the salt this winter. It’s in great shape, just washed and put a nice coat of wax on it for winter, not a single ding anywhere on the truck. We did look at another limited 4Runner and the paint sucked, brand new truck so much orange peel, interior quality all plastic, def a let down compared to this LX, plus heated steering wheel on the lx is a nice touch for the winter.Nice! But what about the 4-runner?
6th gear and towing is no issue-Toyota actually sold land cruisers w 6 speeds with 285 70 r17 (32.8”) tires on rock warrior wheels from the factory. The wheel weigh package was around 76 lbs…Regarding your 33" p rated tires... How is the acceleration and does your truck get into 6th gear and stay there?
