Smaller tires will help with the shakey mirror fix too!
Good luck
Good luck
Don't forget the out/in pix!Making progress got the parts out I needed to swap power steering pump and starter. They where booth newer parts. Almost got the intake plenum of gotta disconnect the wiring harness in cab. Man will I never try that again while in the truck!!
I will I have to take 100 pics just so I know how it all Goes back together.Don't forget the out/in pix!
GMTA. Particularly interested in seeing the positioning and angle of the dangle to get an idea for it's gonna look like for me down the road.I will I have to take 100 pics just so I know how it all Goes back together.
I was going to recommend that. You'll need all the clearance you can get. Good luck!Bumper pulled for extra clearance. Going to try and pull just motor myself will see how that goes!
Yah gonna give it a shot if not I’ll pull the whole dam thing.Also I was able to get the motor and transmission together by myself, it was only a little sketchy. Worth a shot if you give up on reaching the transmission bolts.
6 point are mandatory.Any advice on pulling drive shafts. I soaked them with kreosol tonight. Tried to loosen one and it’s tight. Chalked the wheels and put t case in neutral. I don’t have any 6 point box end wrenches so it may be time to go shopping.
Well done!
