PS Pump Pulley
jvazquez53
El Tractor
San Juan Puerto Rico
Website
www.facebook.com
Does anyone make a power steering pump pulley for the Saginaw pump that the pulley goes pressed (not with the key)?:hhmm:
What pump are you running?
I am running the AGR modified Saginaw pump for my hydro assist. I ended up using a pulley from a Ford to get the right diameter.
I don't know if all Sagiinaw pumps have the same input shaft.
I am running a Saginaw that does not have the key. The pulley gets installed with a bolt that goes into the center shaft that pushes the pulley in place.
So what diameter pulley are you looking for?
I'm just trying to help you out here.
I hate to sound like a dick but asking for a pulley for a Saginaw is like asking for a belt for your lawn mower. Too genreal of a request. What pulley diameter, V-belt I assume, 1/2" or 5/8".
:meh:
1/2" or 5/8" is where the belt meets the pulley? All I know that the pump assembly came from a six cylinder Chevy Nova.:confused:
My AGR pump on my FJ40 goes to a Saginaw steering box but I cannot saw it is a Saginaw pump. It has a 6" diameter pulley from a Ford F-150.
Press fit jsut like you are talking about.
Does the belt fits in the pulley groove? My belt show about less than 1/4 " outside the pulley.
I'll do the same on my side.
Here is what I have. I'm running the 1/2 belt. I'm pretty sure the pulley came off a Ford F-150 at the Pick N Pull.
Is that the Toyota land Cruiser belt? The pump shaft looks like mine the pump is different. My setup is working fine, but I would like to go back to the original land Cruiser belts.
