PS pump compatibility
Seattle
While I have the manifolds off I'm converting over to power steering. I have a gear box from an '84 4-runner and I'm trying to figure out the best pump setup for this. It seems all the saginaw pumps attach to the block via a couple of bolts on head. Not sure if I like this...if going the oem route,
what year PS pumps/brackets are compatible with a Feb 1981 fj40?? I've seen a couple on ebay, which are from early 1980s fj60s. will these work?
Thanks!
Any of the 79-87 2F PS pumps will bolt onto the 1981 block. Be sure to get the cast iron mounting bracket and a straight pulley along w/ the pump.
