when I put a 2" lift on my 4runner the lift came with an extension for the rear proportioning valve for the brakes. In all the info I have read about lifting an 80 I haven't seen anything like this. What is the procedure for this if any? Thanks.
landtank said:I actually made an extension from some 1/2" pipe I bought from Home Depot. I cut it to length and then threaded it to 12mm 1.25 I beleive and then screwed it on the piece on the axle and then used a bolt to secure it to the arm. Worked out real well. One nice thing is that it's adjustable and if you measure before and after distances from the bump stops you can easily position the tube to compensate for the spring height change.
Edit : Changed measurment to X inches , as I can't remember now how far I moved it . However I did base my adjustment from my reading MUD archives , and moved it the standard amount for the lift I put on .
