Propane, What did I just buy? (1 Viewer)
Atkins, Iowa
UPS just brought my Ebay purchase to me today. I had bought a propane setup and was hoping to piece a dual setup for my V-8 FJ40.
These model numbers are not what I have been seeing here on MUD.
Any help figuring out what I have would be great.
Impco VFF-30
Impco CI-30
Impco Model E
The VFF-30 looks like a vaccume shutoff.
I don't know how you would put an air filter on this.
BIG round thing is a vaporizer for turning liquid to gas. Coolant (hot) runs through it so liquid propane can't reach carb.
I think this is what I have
Carburetor. IMPCO carburetors are an air-valve design, using a relatively constant low pressure drop to draw fuel into the carburetor from cranking to full load. The advantage of this type of construction is a strong "signal" or vacuum set up by a metering spring (A) holding the air valve (B) closed. A pressure drop (C) under the air valve of approximately 6" WC (Water Column) is required to open the valve during cranking. Vacuum to the converter (D) and filter/fuelock (D) allow fuel to flow. When the engine is stopped, fuel is safely sealed off within the carburetor, converter and fuellock.
The air-fuel metering upper part of the carburetor, called a mixer, is completely self-contained. It derives it's vacuum feedback signal from the throttle bore.
Converter. The IMPCO converter is a combined two-stage regulator and vaporizer. It receives liquid fuel at tank pressure (approximately 180PSI) from the filter/fuelock (E) and reduces pressure in two stages to slightly less than atmospheric (F). When the engine is cranking or running, a partial vacuum is created in the vapor line to the carburetor (D), which opens the regulator permitting fuel to flow to the carburetor.
In the process of reducing the pressure in the tank to atmospheric, the liquid propane expands to become a vapor, absorbing heat in the process. Water from the engine cooling system circulates through a heat exchanger (G) to avoid freezeup. The regulator seals off fuel flow when the engine is stopped (H).
IMPCO makes three sizes of converter, the Model J which is rated at 100HP maximum, and the Model L and Model E which are rated at 325 HP maximum.
Fuelock/Filter. The filter/fuelock (Model VFF30) is vacuum operated. Upon slight engine vacuum (2" WC), it opens and allows fuel from the tank to flow through a fuel filter, to the converter. Any time the engine stops, whether the ignition key is on or off, the fuel is shut off automatically. It also filters any large particles of solid material out of the fuel before they reach the high-pressure side of the converter.
Should I get rid of the hard lines? It seems like a huge hose I would have to replace it with.
Enigma, if you have something like mine that would be great.
