Hi everybody, you've all been very kind to recommend a few inexpensive projects for me to complete and hopefully get my cruiser back up and running. I'd like to get started on some of them this weekend, but I need a little bit of help in terms of what to look for first.
1. It has been said several times that I should ground/reground the fuel cut off solenoid. Can you please post up a picture of what I am looking for?
2. I also need to replace my fusible link off the battery and for the time being need to go with aftermarket parts since I'm broke, so can you tell me what gauge of wire/quality of fuse to use?
3. Everybody swears by seafoam, so what exactly do I do with it? Just drown the carb?
4. I still have an energy leak that is draining my battery. Both the Batt and the Alt have been tested and are ok, what else should I check? Could this be related to the fuel cutoff solenoid and/or fusible link situation?
5. I can't remember which screw is which as far as idle adjustments go, could you please tell me (again? sorry.)?
6. (This one's real specific... in an alternate universe!) There is something that changes the way the engine runs at higher altitudes and I think it's one of many things that has gone screwy. How do I adjust it?
Thank you once again for your help. Without the help of the people on this forum, my 60 would never even have a chance of running again.
-Ian
-Ian
