Project in Progress....Help Needed
ID
Slee Light Harness Prob...Help
I just finished installing the Slee light harness. However, when I was testing the lights, it seems that the high beams are running instead of the lows. I followed the instructions exactly and can't seem to figure out what the problem is. Any suggestions?
Dumb question first...
Are you sure you put the bulbs in the right spot? Yeah...I said it's a dumb question.
If so, do the low beams work at all...or is it just always on high?
Doug the bulbs are installed correctly. I just did the install the way the instructions noted to do it. The low beams do work but only when the high beam is set to on. The hi beams are just on when the light is switched to on.
Call Christo, I had the same problem and there was a quick fix. You will not be making friends while driving at night until you get it fixed. :D
Yeah, I know.
Not going to drive the truck tonite. Hopefully will have fixed before having to drive at night.
