This Cruiser build was recently completed and has
less than 3000 miles on the build.
No expense was spared and you are looking at years of
countless hours spent to get this cruiser to what it is today.
BE THE TALK OF THE DUNES > THE MOUNTAIN > THE TOWN!
FREE Shipping
to the Lower 48 U.S. States
if sold for the asking price of $35,950.00
Shipping arrangements and costs will be the buyer's responsibility if not sold for the asking price but offers are welcomed.
FREE Shipping
Exterior:
CORVETTE Yellow Base Coat Clear Coat Paint
Roll cage and all Accessories Powder Coated in a grey hammer finish
Fully metal finished prior to paint
1976 Windshield Frame
Front bumper built into an air reservoir which features a water drain and is setup for a Warn Winch (Winch was Stolen)
Rear bumper made from 3”x 5” ¼ wall tube and features a trailer receiver with flat four trailer wiring plug
Hood Shaved: Removed wind shield hold down latches and resting blocks
Under the fenders and hood were sprayed with rocker shutz for added protection and sound dampening for comfort
Upgraded Head Lights BRIGHT!
LED Tail Lights
Custom Front Turn Signals
New Complete Best Top Soft Top with full or half doors
Body Armor made of 3/16 steel diamond plate and then Powder Coated in Hammer Grey
Custom One Off rocker guards are made out of ¼ diamond plate and Powder Coated Hammer Grey
All most everything was assembled with Stainless Button head Fasteners: All were hand polished before installing
Interior:
Custom Bucket Seats
Rebuilt the floor: Removed the fuel tank sump on the passenger side of front floor( not the dog house), plasma cut the floor and welded in new steel
Custom built dash made out of 10 gauge Sheet metal and powder coated in Hammer Grey
All New Water Proof switches in the dash
New Auto Meter gauges
Kenwood Stereo system Rocks with a 600 watt amp which powers two 6 1/2's speakers enclosed in water proof speaker boxs mounted on the roll cage, and a Sub which sits on the floor (Easily removable for hunting trips or your toys)!
Tilt / Collapsible Steering column with Borgeson Steering components
Billet Steering Wheel with a leather grip
Custom One Off Billet Accessories including: Head Light Switch Knob, Steering column levers, and Transmission Shifter Knob
LED Interior Lights
Custom built full family roll cage, stereo speakers are built in with wiring ran inside the cage
Sprayed the inside of the floor with bed liner spray for added protection and additional sound dampening for driving comfort
After Market Interior Heater: BLOWS HOT!
Factory Fuel Tank was removed and a custom built Fuel Cell built for between rear frame rails. 1/4 Plate was used for the bottom of fuel tank for added strength and safety
All most everything assembled with Stainless Button Head Fasteners: All were hand polished before installing
Most parts were powder coated before installing.
Drivetrain:
Fully Built 350 CI Chevrolet Small Block with w/ Edlebrock projection (multi Port) Fuel Injection
Advance Adapters Bell housing for transmission
Advance Adapters Rear transmission mount and Motor mounts
Completely Rebuilt Toyota landcruiser 4 speed transmission: All new bearings seals and syncros
Advance Adapters Heavy duty Orion 35 spline 4:1 Transfercase
High Angle Drive line of Paradise, CA New long slip front driveline, New CV Rear driveline
Stock cruiser axles with 4:10 gears
Front and Rear ARB Air Lockers with ARB Compressor
Warn Locking Front Hubs
Also has a York Air Compressor for On Board Air System
All new 12 Circuit Painless Wiring Harness
All sensors and computer are new
Optima Yellow Top Deep Cycle Battery
Suspension and Handling:
Spring Over Axle Lift
Cut and turned the front axle 12 degrees to allow for proper pinion angle and proper factory caster angle: You can fly down the highway comfortably and safely!
Custom built steering rods with hyme joints: Super HEAVY DUTY!
Front shackle reversal: DOM tubing used for the frame rail sleeves
All new Rancho bushings through out the rig
New Rancho RS9000 Shocks
Rebuilt Brake Booster
4 wheel disk brakes with all new brake lines and Stainless flex lines: Toyota Front Disc Brakes / GM Conversion Rear Disk Brakes: STOPS ON A DIME!
Saginaw Power steering conversion with Power Steering Cooler: Turn Lock to Lock sitting still on the pavement with minimal effort (Your Grandma Could drive this Cruiser!)...
Rims: 5 - 10”x 15” Chrome
Tires: 5 - BRAND NEW 35x12.50 BFG Mud terrain
Additional Photos Found here:
Photos
Call: 530-966-1300
or
Email: CruiserInnovations@gmail.com
If you have any further questions
