SOLD 1982 TOYOTA FJ40 LAND CRUISER *** U.S. Specs
Newnan, GA
Website
www.cwcruisers.com
Year
1982
  1. 40 Series
Newnan, Georgia United States
Mileage
92157
Color
white
Outside Link
https://chriswade.smugmug.com/SOLD-1982-White-ED-CA
U.S. Specs
*** This FJ40 has the most desired features: late model year, highway differentials (3.70), Factory, larger factory fuel tank in rear, All original emissions. Purchased new in California. It was formerly a Los Angeles California County Sheriff’s vehicle. You can still make out the round seal and Sheriff decal. It is a US Version Land Cruiser which makes a huge difference in comfort, safety, and value.
** BODY CONDITION **
This Land Cruiser does not have the common rust issues. From what I can tell paint is mostly original Toyota, color code #033.
NEW:
Hood & windshield hooks
  • • Toyota & 4WD emblem
  • • Apron emblems
  • • Tail light lenses and gaskets
  • • Bumperetts
  • • OEM Front & rear door weatherstripping
** INTERIOR CONDITION ** Front Seat Upholstery is new. Front and rear seat belts. Original floor mats in place. All dash controls, gauges, and lights in working order. Jump seats and seat belts in place.
** MECHANICAL CONDITION ** 92,157 miles on stock Toyota six cylinder (2F 4.2 Liter). 4-speed synchronized transmission, 4-wheel drive. BF Goodrich All Terrain Tires (31x10.50x15) mounted on factory sand blasted and powder coated wheels.
*** Extensive professionally installed mechanical updates $21,000.00 in documented receipts:
Birch’s Automotive Arlington TN
Miles: 86,429 5/8/2017
  • • Exhaust pipe $69.95 labor $396.00
  • • Muffer $64.40
  • • Man-A-Fre Shackle reversal kit $474.30 labor $297.00
  • • Re-arch front & rear springs $1,660 labor $693.00
  • • Overhaul front knuckles $2,200
  • • Bearing & seals $183.18
  • • Completer Tie rod end overhaul kit $399.50 labor $118.80
  • • Drag link kit $90.02
  • • Center arm $490.14 labor $198.00
  • • Steering relay rod end -2 labor $108.90
  • • Steering gear $1,200.46 labor $316.80 (remove, install, and overhaul 2 door worn & ball nut type manual steering
  • • Steering stabilizer $157.78
  • • Shock absorber 4 $445.50
  • • Brake wheel cylinders 2 $69.20 labor $138.60
  • • Brake drums 2 $184.96 labor $59.40
  • • Brake rotors $54.33
  • • Radiator $751.08 labor $108.90
  • • Major transfercase overhaul $644.30 labor $1,287.00
  • • Poly spring bushings $273.60
  • • Differential service $149.95
  • • Transfercase service $149.95
  • • Alignment $149.95
  • • Used rear differential assembly $600.00 labor $198.00
  • • Mini fuse holder $9.95 labor under hood $148.50
  • • Fuse holder $19.90 labor replace fuse box $396.00
  • • Thermostat $57.98 labor $59.40
  • • Water pump
  • • Coolant hoses $82.16 labor upper $59.40 lower $89.10
  • • Fan belts $49.69
  • • Air filter $35.95
  • • Engine oil cooler, remove & replace $99.00
  • • Coolant service $119.95
  • • Transmission flush $149.95
  • • Brake system flush &109.95
  • • Axle shaft bearing remove & replace $198.00
  • • Repair wiring to parking brake switch $99.00
Cool Cruiser part order 3/22/2017
  • • Kick vent weatherstrip pair $9.98
  • • Outside belt weatherstripping $36.03
  • • Front Toyota door weatherstripping $216.20
  • • Rear Toyota door weatherstripping $164.51
Costco Battery 9/15/2021 $109.74
Birch’s Automotive Arlington TN 1/31/2020 miles: 88,785
  • • Water pump $182.67
  • • Thermostat $94.02
  • • Thermostat housing seal $24.34 labor $87.00
  • • Valve cover gasket set $78.20
  • • Starter $192.23 labor $145.00
  • • Water pump gasket $27.30 labor $435.00
  • • Drive belts 2 $78.88
  • • Valve clearance & re-tourque head $507.50
Imperial Toyota Milford MA (ebay) 6/29/2022
• Radiator $499.00
**** Vehicle ID# JT3FJ40C1C3357249
Clear Georgia Title licensed and registered in my name. Frame stamped number, firewall plate, door pillar plate all match title.
Pictures before, during, and after restoration can be seen here: 1982 White "ED" CA - Chris Wade - https://chriswade.smugmug.com/SOLD-1982-White-ED-CA
***AS DESCRIBED THIS FJ40 IS STUNNING AND TURNS HEADS WHEREVER IT GOES. THIS YEAR MODEL IS VERY RARE AND SECOND TO THE LAST IMPORTED. COMES WITH SOUGHT AFTER 3.70 DIFFERENTIALS AND FACTORY 22 GALLON FUEL TANK. HARD TO FIND ITH THIS ORIGINAL RUST-FREE CONDITION. LOCATED JUST OUTSIDE OF ATLANTA, GEORGIA. $36,000.00
404 819-6943
Wow, just wow. I wish I was in a position to own this.
Chris @Wadesters ,
I remember this truck and its twin driving past my house in the San Gabriel Mountains back in the day. They were lightly used but most appropriate where they patrolled. There was one used on this end of the range and its sister used on the opposite far end. If I had the space to keep it, it would be SOLD today.
Good luck with your sale.
Nice rig indeed. Well documented sale ad. Fair price! GLWS.
Another beauty…I have seen this somewhere but can’t remember where
Super cool! Is there any police hardware or remnants left in the truck?
Looks like a great example with some interesting history.
