Nice!
To answer old red, yes the 4 preceding fj40 designates 1964
As a cross reference, I’ve pinned my rig’s build date to sometime between mid-Sept and mid-Oct 1964, based on a date code on the fuel filter of 1 Sept 64, and knowing that it was first purchased here in Oregon in Nov 64.
Brain fade and typos. All those spots I posted ‘64’ should have said ‘63’. I’ll edit and correct my post.If yours was built sometime between Sept. and Oct. 1964 as you say, then what is the significance of the "3" preceding FJ40 in your vehicle identification number?
it could quite easily be an early 64 as back then, vehicles were titled (and brass tagged in the case of the mid to late 60s rigs) when they were sold to dealerships.Keith, I’m questioning the Jan. 1964 build date, thinking that it would probably have been much later in ‘64. The leading ‘4’ in your VIN indicates a ‘64 build, but Toyota typically didn’t start the next model year production until August or so. So for it to have ‘1965’ stamped on the data plate would tend to support a build of August or later.
But note that the VIN data plate pictured on the first page of this thread is stamped ‘1965’. Same as my 40 which has a VIN starting with 3, but the plate is stamped 1964. It’s easier to tell that mine is truly a ‘64 model year as there are plenty of differences between those two years. A bit tougher to tell between ‘64 and ‘65. But Toyota apparently considered Miss Kitty to be a ‘65 model year (assuming the data plate was stamped in Japan, as I have always thought).it could quite easily be an early 64 as back then, vehicles were titled (and brass tagged in the case of the mid to late 60s rigs) when they were sold to dealerships.
an example of this is my annie, is vin 2fj4016523 is titled as a 1963 and was sold from a colorado dealership in 62. another member here owns the rig three digits later in vin (16526). his is titled as a 1962 and was sold in the east somewhere in 1962.
Yup. That’s a full year after mine was cast. Which means your engine was built much later than January. Cast blocks can’t be machined for some time while the casting “ages” or “cures”. Sometimes months. As I understand it, I don’t think they could machine and assemble that motor so soon after casting that the truck could have a January build date. In my truck’s case, the lag between block casting and final build was something like 9 months.Casting block date of Jan.13, 1964?
Ok, I'll box them up and bring 'em down.Sure, you could hide them in the glove box. But if they aren’t out where they can be seen and monitored while driving, I don’t see the point. Which is why I pitched mine. I’ll live with idiot lights. Especially if the choice is gauges or my PTO...
