Prado 90 Motor into Prado 70
  • Thread starter Thread starter oldblue
  • Start date Start date
oldblue
Has anyone transplanted a Prado 90 intercooled motor into a Prado 70 series that at presant running a 1KZ-TE Motor.
I'm aware of the Bonnet needs to be altered and the sump changed over. How do you get on with the ECU , can I still use the 70 series ECU?
Most of everything is the same, however using a 90 ECU may be advisable as it is probably mapped for the intercooled motor.
Also you will need new throttle cables as they are different between Non and intercooled 1KZTE's
Is your auto or manual?
As the Autos are different....
