Hey guys, I've read up in the sticky what there is on windows, and I can see there can be multiple things that can affect window travel. For instance, the front passenger window is very slow when using the driver main panel switch, but is fine/zippy when using the passenger door window switch. So I plan to go into the driver switch and try to clean up pitting, etc..
The driver window failed on me at half way suddenly recently. I'm trying to get an accurate diagnosis of the source of that failure. I have the repair manual, but I'm not confident of my findings there. I thought that maybe I could describe the symptoms/situation here and maybe some of you guys have seen similar. I'd like to do that before ordering a new motor.
The driver widow does not mechanically move at all when the window switch is activated up or down. I can hear the relay or something trying to command the movement, but nothing. I also tried what the manual says to put battery power straight to the window motor pins briefly to verify activation. Nothing.
Any ideas? Thanks.
Any ideas? Thanks.
