ARCHIVE Power steering hose, fitting and cooler upgrades
NLXTACY
Wits' End
Medford, OR
On my turbo test mule#3 I went ahead and stripped out all of the power steering hoses (along with everything else 🙄) and am doing the typical Derale cooler upgrade some have already done to replace the paperclip.
This is going to be the “instructions” to do that with the kit I just put together for the 1FZ trucks. This kit replaces every part of the low pressure circuit with new Continental oil hose, new push lock fittings, Derale dual pass cooler that I anodize black, new OEM clamps (to the reservoir and pump) and drill/tap and mounting hardware.
But I’m in Philly right now to attend CMCC2019 and won’t be back until Monday to mess with this.
EDIT: This project is done and I've also included it on the site:
I’ve also been getting a few requests to also make an upgrade cooler/hose kit for the 3FE Land Cruisers.
Not that it’s difficult to do but you need to keep in mind that this would be one of those types of mods that pretty much makes no sense NOT to also change all of the power steering hoses at the same time.
On the 3FE the power steering pump and reservoir is one unit AND it’s pulley driven vs separate and gear driven on the 1FZ.
The issue is that both the high pressure hose (red) and the low pressure hose (green) run together it’s entire run. So why change one without the other?
Adding a single pass cooler is easy as well as replacing all the hose with high end oil cooler hose and push lock fittings. But you will still have a hose separate and below an added cooler. Just seems odd. My guess is the high pressure hose is crazy money from Toyota or just NLA.
Just food for thoughts folks.
Sounds interesting.
Instructions:
• First decide if you are doing the pressure hose at this time or not. The pressure hose is about $300 from Toyota or about $30 from various aftermarket sources. Doing this hose at the same time as the rest of the kit does makes things smoother. The instructions follow the assumption that you are indeed changing the pressure hose.
• The next step in this mod is to drain your power steering system of fluid. The easiest way to undo the bottom of the smaller resevoir hoses and have a bucket ready to catch the fluid. The reservoir will drain. Then you can remove the bottom of the larger reservoir hose and drain out that. From there you can remove both return hoses completely.
• There are two bolts holding down the paperclip cooler that are above the front crossmember, under the radiator, that need to be removed in order to start removing the paperclip.
• There is a bracket on the driver's side inner frame that is the junction point of the low and high pressure hoses. Remove the 12mm bolt and the main bracket and high pressure how can now go to the next step of removal.
• On the steering gearbox you have an 16mm and 17mm threaded port. These are sized on the box so that you really can't make a mistake. Go ahead and remove both of these fittings using a flare nut wrench. Access to these is challenging but going in from the wheel well helps.
• The paperclip can be removed without taking out the radiator but it does take some finagling.
• Removing the banjo bolt on the pump side of the high pressure hose is a pain in the ass. Be sure to hold the nut on the pump still and you work getting the banjo bolt out. Its a bear. Be sure to remove the two copper gaskets when the hose and banjo bolt come out.
• At this point you should have removed the small and large hoses and clamps from the reservoir, the high pressure hose and the paperclip.
• Now you can move on to the install by just hand threading in the 1/4NPT to 6AN flare fittings into the black anodized Derale cooler. DO NOT TIGHTEN.
• Take the two 90º ends of the hoses and fish them thru the driver's side hole in the front crossmember until they are poking out thru where the cooler will be mounted.
• Place the cooler onto the crossmember to where the fittings are facing the hole where the two hose 90º are facing. Go ahead and thread the 90s onto the flare fittings on the cooler. The orientation doesn't matter.
• Get the cooler positioned so that the two hoses are dead center to the crossmember hole. Once that is decided, go ahead and mark the two REAR mounting holes. NOTE: center the mark as best you can since you will be drilling and tapping those holes.
• Now that you have the two rear holes marked, go ahead and unscrew both the 90s and the 1/4NPT fittings from the cooler.
• Line up the marks from the rear up again and now mark the two front holes.
• Start by drilling out the two rear holes first by using the supplied drill bit, then trap the holes using the supplied tap. Use cutting oil.
• Once trapped and deburred, test fit the mounting for the cooler and use the supplied bolts. Once you have the two rear bolts in hand tight, note the marks on the front two mounting holes. Are they still good where marked or should it be adjusted?
• Once confirmed, drill and then tap the two front holes.
• Using teflon tape on ONLY the NPT ports (never the flare side of the fitting), thread in and tighten the 1/4NPT to flare fittings. Do not over-tighten.
• The cooler is now ready to be mounted using the supplied bolts.
• You can now attach both hoses with the 90º fittings but hand tighten for the moment.
• This is the best time to not only install the pressure hose from the gear box to the power steering pump, but its also a good time to thread in the supplied 16mm to 6AN steel adapter fitting into the other hole in the gear box. Tighten down both the pressure hose and fitting into the gear box.
• Place a new copper washer under the banjo fitting onto both sides of the pressure hose before running the banjo bolt thru. then tighten the banjo bolt and hose per the FSM torque spec.
• Going back to the hoses from the cooler, route the hoses from the crossmember, to the frame bracket and behind the mounting bracket of the pressure hose. Using the stock holding bracket from the paperclip could be possible but I didn't see the need for it and it can be difficult to make it work. Your call.
• The hose with the 90º fitting now goes onto the steel fitting you previously tightened down into the gear box.
• The longer hose without a fitting now gets a small supplied clamp before it is pushed onto the small tube of the reservoir.
• The 12" long 5/8" hose gets the two larger supplied clamps and goes from the pump to the large port of the reservoir.
I’m blown away how many folks have done this upgrade. Thanks everyone. I have another 20 coolers ordered and will do another anodize run as soon as they come in.
Do you have part numbers to the high pressure hose by any chance? Or even better do you sell a hose kit? I’d really love to do a kit like this but recent repairs have killed me financially and of course damned google send me here when I search 😓
I’m looking to find the best place to buy all new hoses. Then eventually replace my pump.
Thanks
Thanks
I don’t have the high pressure part numbers handy. I ordered a few different ones and I just chose whichever brought me the most happiness. I honestly can’t remember right now if I used ultimately used Gates or not.
The low pressure hoses you can get here:
44411-60430 is the OEM high pressure hose assembly from the pump to the box. You will need to remove the pump to remove/install.
Is there something different on the OEM hose vs aftermarket hoses? I didn't need to remove the pump to install. Hmm...
It was impossible for me to get the high pressure line off the pump with it in place. The pump and the lines come out together pretty easily.
I considered that at first but I was able to get the banjo bolt off without much drama.
